Multiplex Module-- Boot/tailgate release button not working - Page 3 - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Electronics
Reply
Thread Tools Display Modes
Old 13th April 2012   #11
benkrzysica
benkrzysica is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Re: Multiplex Module-- Boot/tailgate release button not working
Quote:
Originally Posted by jamesfr View Post
Hi Tim
My Interior multiplex module was damaged after jump starting the car as I had not used it for a few months,there is no fuse protection for the multiplex module there must have been a surge.
As it was only my tailgate lock that was affected and I was quoted +€400 to replace it, I decided to run a new 12V feed from the cigar lighter direct to a new 12V switch which I managed to click into the existing tailgate switch.
The tailgate now opens but I need to insert the key card into the slot before it will open.On leaving the car the tailgate opens until the car is locked .I could have spent more time looking for a feed which operates with the key card but it's fine the way it is.
I took a local Earth from the tailgate.
cost about €10 compared to €400+
You have a slightly more serious problem with the window/door
Are you sure it's the multiplex module? have you jump started the car recently?
I have exactly the same problem and my car has failed it's MOT because the boot will not open. Please could you tell me how you created the new feed. It seems very clever, but I have no idea where to start. I have the Haynes manual with the wire diagrams but that's about it.
Thank you very much.
Currently in benkrzysica's garage:
2003 Renault Megane II 1.5dCi
benkrzysica is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 13th April 2012   #12
tim c
tim c is
has no status.
Junior Member
Changing the rear door handle solved my problem
Currently in tim c's garage:
2010 Grand Scenic 1.9 dci 65K kms; 1968 VW beetle 1500
tim c is offline   Reply With Quote Quick reply to this message
Old 13th April 2012   #13
jamesfr
jamesfr is
has no status.
Junior Member
Threadstarter
I actually took the easy route and took a feed from the front console cigar lighter,this meant that the key needed to be in the ignition to open and close the boot but I was happy with that.
It was pretty easy taking the boot panel off and running the cable under the carpet.
I used a local ground cable next to the lock and just ran 1 cable for the feed .
You may take more time and find a power source which is active when the doors are opened
Good luck
jamesfr is offline   Reply With Quote Quick reply to this message
Old 6th May 2013   #14
NigelParkinson
NigelParkinson is
has no status.
Junior Member
Hi Tim
As it was only my tailgate lock that was affected and I was quoted +***8364;400 to replace it, I decided to run a new 12V feed from the cigar lighter direct to a new 12V switch which I managed to click into the existing tailgate switch.
cost about ***8364;10 compared to ***8364;400+
Hi, I have jump started my 2005 scenic and now just the tailgate solenoid does not get a feed to open. From above looks like I've damaged the interior multiplex module? But what and where is this please?? Can I not dismantle and repair it? Thanks
NigelParkinson is offline   Reply With Quote Quick reply to this message
Old 15th May 2013   #15
NigelParkinson
NigelParkinson is
has no status.
Junior Member
Smile Re: Multiplex Module-- Boot/tailgate release button not working
FIXED !!!!
Thank you so much to all those that subscribe to this excellent site. My 2004 grand scenic tailgate and rear fog lights had stopped working after incorrectly jump starting after flat battery. Removed UCH took apart and found 'fried' 100 ohm flat pack IC resistor which grounds the four VP750 power mosfet switches. (See a post about same by someone else for excellent description and pictures). Soldered on replacement resistor using magnifying glass and now all working correctly.
Reply
Tags
boot or tailgate, button, module, multiplex, release, working
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
