Clio 1.5 DCI 65 Fan belt adjustment! - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 11th October 2010   #1
P11SCL
P11SCL is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi guys and gals,
this is the first post on the forum as i have just bought the above car.
Nice wee 54 plate, 1 owner, 55000 miles with full history.
Now i was told the timing belt had been done, but im still waiting for the previous owner to get me the reciept.
Anyway,,,,,,,,, the fanbelt seems to be slipping and squeeling, only when the alternator is under load 1st thing in the morning.
How easy is it to adjust? i see the bolt and the adjuster, is it just a matter of tightening it up a bit? And how easy is it?
Steven
Currently in P11SCL's garage:
Renault Clio 1.5 DCI 65 Dynamique, BMW E36 328i Sport
P11SCL is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by P11SCL
Clio 1.5 DCI 65 Fan belt adjustment! Engines tolsen 3 8020 11th October 2010 11:18 AM
Sponsored Links
Advertisement
Old 11th October 2010   #2
Sub2ltr
Sub2ltr is
has no status.
Junior Member
Thumbs up Re: Clio 1.5 DCI 65 Fan belt adjustment!
Steven,
I have just changed the cam belt on my sons 03 plate Clio (1.2), this required the alternator belt to be removed, tighening is easy, there are 2 bolts, 1 at the top (pinch bolt) on a slotted alloy bracket, the other is at the bottom and just needs to be slackened off slightly, feel the amount of play in the belt before undoing either.
then get a piece of wood which will fit between engine and alternator, slacken off both bolts and using the wood lever the alternator away from the engine to tighten the belt slightly (just do a small amount - don't over tighten the belt), do up both bolts and test, it may take a couple of goes, and you may need another body to tighten the bolts while you hold alternator in correct position.
Pretty easy though, belts are cheap so it may be worth replacing with a new one if it's looking a bit tired.
Hope this helps
Ian..
Sub2ltr is offline   Reply With Quote Quick reply to this message
Old 11th October 2010   #3
roby37
roby37 is
has no status.
Diamond member
Nominated 1 Time in 1 Post
If it is the same as my scenic 1.5dci it is a spring loaded tensioner which is self adjusting. Needs urgent investigating as a failed aux. belt can foul the cambelt.
If it is, a 16mm cranked spanner is needed to release the tension on the belt for removal.
Currently in roby37's garage:
2005 Grand Scenic 1.5dCi
roby37 is offline   Reply With Quote Quick reply to this message
Old 11th October 2010   #4
tolsen
tolsen is
has no status.
Banned User
Nominated 0 Times in 9 Posts
Nominated TOTW/F/M Award(s): 3
K9K engines with airconditioning seem to have an automatic tensioner. K9K engines without aircon are manually tensioned. Belt should be tensioned so belt will vibrate at 234 +/- 5 Hz on bottom horizontal span.
Currently in tolsen's garage:
Trekka 1.9 DCI, Smart Cabrio Cdi (65 - 85 MPG) & Ford Transit 2.2 Duratorq TDCi
tolsen is offline   Reply With Quote Quick reply to this message
Reply
Tags
adjustment, belt, clio, dci, fan
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
