Re: Renault Megane Scenic Auto Gearbox Problem
I'd be taking it to a Renault specialist like yesterday. Doesn't need to be a dealer but someone who knows the cars and has a decent guy reputation.
First Q is what sort of trans fluid the AA guy put in it? What year and what transmission is it? If it's the DPO, the problem may well be a sensor or solenoid on the pressure side of the gearbox. If it were low on oil it could display those symptoms. The DPO usually displays those symptoms when cold and they go away when hot from my experiences but yours could still be that problem. Re-reading it, it still sounds like pressure related but that the sensor may play up when hot.
Did they pull any fault codes from the ECU? Have someone with full diagnostic ability look at the car.
I would expect a torque converter problem to be constant and not allow the car to move at all or lock up and not release.
Currently in OzRX4's garage: 2001 Megane Scenic RX4 Privelege Verve, 2003 Clio Privelege 1.4auto, {son's car}
