Clio Auto Gearbox Oil Change - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Cars & motoring
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Cars & motoring
Reply
Thread Tools Display Modes
Old 15th August 2006   #1
Auto Addict
Auto Addict is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Has anyone ever changed the Auto Gearbox oil in a Clio 1.4 RT (1993).
Haynes manual looks a bit complex.
Currently in Auto Addict's garage:
Clio 1.4 Auto
Auto Addict is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Auto Addict
Renault Clio - Auto Box Problem Engines Lagdti 4 1132 25th September 2007 04:55 PM
Steering Problem Cars & motoring Clio RSi 5 1695 22nd August 2007 12:54 PM
Clio front wishbones Clio chris m 6 2317 6th April 2007 03:51 PM
Clio Auto Gearbox Oil Change Cars & motoring Auto Addict 9 5168 15th August 2006 08:11 AM
Clio Alarm System Electronics Auto Addict 2 1643 13th February 2006 05:15 PM
Sponsored Links
Advertisement
Old 15th August 2006   #2
faultman
faultman is
has no status.
Diamond member
is it a 3speed or 4 speed box
Currently in faultman's garage:
1997 renault laguna 2lt
faultman is offline   Reply With Quote Quick reply to this message
Old 15th August 2006   #3
chris m
chris m is
tired but hopeful
Let's be carefull out there
chris m's Avatar
Nominated 0 Times in 4 Posts
Nominated TOTW/F/M Award(s): 3
Ok I'll assume that the 93 & 94 are the same and you have the orange topped dipstick at the front LH of the engine.
It's best to put car on axle stands as you need to get under engine.
Once underneath there should be a nut / hex head at the back left of the gearbox, this is the drain plug, remove and collect oil in appropriate container.
Replace plug securely and drop car to level ground
Refill through the dipstick tube, akward to get to but ok using a funnel.
note: allow plenty of time for oil to seep into box and check levels with engine running as the torque converter oly fully fills when spinning.
Oil grade : Dexron type ATF
Total capacity : 5.7 litres.
The haynes manual refers to a 4spd box whereas the early Clios were a 3spd hence the poor instructions.
__________________
Currently in chris m's garage:
2000 Scenic 2.0 16v Monaco, Peugeot 207sw 1.6 HDi
chris m is offline   Reply With Quote Quick reply to this message
Old 15th August 2006   #4
Auto Addict
Auto Addict is
has no status.
Junior Member
Threadstarter
It's a 4 speed auto, thanks for your replies guys.
Just a bit of history, it's my wifes car, 24,000 miles from new, mint condition.
Clio 1.4 Auto
Old 15th August 2006   #5
chris m
chris m is
tired but hopeful
chris m's Avatar
Let us know how you get on
Reply
Tags
auto, change, clio, gearbox, oil
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
