Renault Scenic - Won't start. - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Cars & motoring
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Cars & motoring
Reply
Thread Tools Display Modes
Old 16th August 2006   #1
Eyehawk
Eyehawk is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Sorry , I am new so go easy on me !
Owner of a 2000 Scenic Alize 1.6 for one month. No problems till saturday.Went to nearby town's Asda .No problem getting there but on returning to the car it won't start. Needles went up and down and warning lights just flashed but nothing more . Breakdown service came out and jump started the car to which it started and we were able to get home.He suggested that if it happens again we might need to get a new battery. On switching it off and back on again at home I had exactly the same problem. Bought new battery next day . With new battery the car then started but didn't idle . Took the car for a 20 mile drive to which everything was fine when we got back home.Started as soon as the key was turned and idled perfectly. Today it won't start. The enigine is turning and turning but nothing more. Any Suggestions ?
Currently in Eyehawk's garage:
2000 Renault Scenic
Eyehawk is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Eyehawk
Renault Scenic - Won't start. Cars & motoring Eyehawk 3 4326 16th August 2006 06:37 PM
Sponsored Links
Advertisement
Old 16th August 2006   #2
Eyehawk
Eyehawk is
has no status.
Junior Member
Threadstarter
Just an update on the situation.. Searching the Forums everybody is mentioning the TDC sensor. I did as one person mentioned which was to unplug the Sensor and to see if the car starts.It didn't , so I just plugged everything back and thought I'll give it a try ...Yes, it started .. Am I to take it there is a problem with the TDC Sensor ?
2000 Renault Scenic
Old 16th August 2006   #3
Horatio
Horatio is
has no status.
Platinum member
Horatio's Avatar
Nominated 0 Times in 7 Posts
Nominated TOTW/F/M Award(s): 8
Maybe, maybe not. The engine won't run without a signal from the TDC, so if you unplug the sensor, you'll definitely prevent the engine from starting.
It's possible that you had a loose connection to the TDC and disconnecting/reconnecting the cable sorted it out. But as you have an intermittent fault, it's equally possible that the fault just happened to go away while you were messing with the wiring.
Intermittent faults are always the worst to diagnose
Currently in Horatio's garage:
2010 Laguna III Initiale.
Horatio is offline   Reply With Quote Quick reply to this message
Old 2nd October 2006   #4
Eyehawk
Eyehawk is
has no status.
Junior Member
Threadstarter
Update
With there being so many other threads with problems relating to the Tdc sensor I decided to replace it and since then haven't had any problems with it starting . Thanks for the help to all on this Forum !!
2000 Renault Scenic
Reply
Tags
renault, scenic, start
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
