MAF (Mass Air Flow) Sensor Location on Scenic 1.9 dci - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Exhausts
Notices
Exhausts Exhaust Systems, Catalysts, DPF, FAP, etc.
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Exhausts
Reply
Thread Tools Display Modes
Old 20th November 2010   #1
dsom73
dsom73 is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
This is the first time I haven't found the answer to my question on this forum, so I've been forced into registering to ask it after 2 years of lurking. Just goes to show the wealth of info on here...
Anyhoo...
Renault Scenic 1.9 dci on a 52 plate. Diognosed as having a problem with the Air Mass Meter this morning.
Symptoms:
She loses power intermittently: sometimes just loses accelleration (usually up hill, but not always) but sometimes it's like hitting a brick wall, or at least a rev limiter. Dipping the clutch when it happens doesn't cause it to rev as you'd expect.
Doesn't matter if it's hot or just started, although more often than not, it's within the first 15 miles.
"Electronic warning" light comes on on the dash occassionally but not always.
As I said, Local Garage diagnosed it as requiring a new Air Mass Meter and quoted £253 +vat to replace. Seems abit steep to me so I'll be doing it myself, whether I know what I'm doing or not. Obviously, I want to know as much about what I'm doing as poss before I start.
Problem is, I can't find the damn thing, so I can't find a part number/ oem number to order a new one. I assume it'll be connected to the air box somewhere.
Any help would be massively appreciated: locations, directions, instructions, photos, videos, come round n do it for me. Whatever you can do, I'd be very grateful for.
Cheers
Andy
Currently in dsom73's garage:
Renaul Megane Scenic
dsom73 is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by dsom73
MAF (Mass Air Flow) Sensor Location on Scenic 1.9... Exhausts dsom73 3 15664 20th November 2010 04:32 PM
Sponsored Links
Advertisement
Old 20th November 2010   #2
madnoel10
madnoel10 is
has no status.
Technical Supremo
Nominated 12 Times in 65 Posts
Nominated TOTW/F/M Award(s): 26
Re: MAF (Mass Air Flow) Sensor Location on Scenic 1.9 dci
I have seen numerous code readers come up with MAF faults and it turned out not to be the case - this occurs in around 70% of cases. As Renault use a different protocol in their ECU's not all code readers are compatible.
So be careful before spending your hard earned cash.
The MAF sensor is usually located close to the air filter - see attached photo for a sample unit - it may help you identity it. Before removing the MAF try disconnecting its multi-plug and see how the car runs. Disconnecting forces the ECU into default mode so overiding many sensors. Sadly this method of testing is no guarantee the MAF unit is faulty but it may help nail down the likley problem. Try disconnecting and come back to us. It is rare for MAF units to have intermittent faults - when they go they usually don't recover.
I take it the EGR valve has had a good cleaning and checked if operating correctly.
Click image for larger version
Name:	LAG Dci MAF sensor.jpg
Currently in madnoel10's garage:
Honda Civic 1.4l
madnoel10 is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to madnoel10 For This Useful Post:
fredkelly (18th November 2012)
Old 20th November 2010   #3
Lagdti
Lagdti is
back.....sort of...:o)
Veteran Member
Technical Supremo
Lagdti's Avatar
Nominated 1 Time in 1 Post
Have a look here,it's concerning a similar fault and shows an engine bay layout on a similar aged Megane.....
http://www.renaultforums.co.uk/showthread.php?t=57084
I'm pretty sure the MAF sensor is down the back of the engine.
Currently in Lagdti's garage:
2004 Saab 9-5 HOT Aero and a 2001 Audi A3 1.8 Turbo
Lagdti is offline   Reply With Quote Quick reply to this message
Old 20th November 2010   #4
dsom73
dsom73 is
has no status.
Junior Member
Threadstarter
Crikey, wasn't expecting a reply so quickly, especially on a saturday night. You guys must live n breathe this stuff, I'm obviously in the right place
It's funny you should both mention the EGR valve actually. When I searched these forums a couple of weeks ago, my symptoms pointed me towards either a knackered fuel filter or a clogged EGR valve. Someone said both might as well be looked at so I fitted a new fuel filter and priced up a new egr valve.
The guy at the trade counter suggested I try this spray stuff to clean the egr valve out without having to take it off. Just remove the air filter and spray it in bursts while the engine's being revved. Maybe it didn't clean it as well as I'd hoped, if at all. Symptoms didn't disappear anyway.
Seems quite a straight forward job to take off and clean so I'll start there. Suppose I was just being lazy with that spray...
Cheers lads, I'll let you know how it goes.
The Following User Says Thank You to dsom73 For This Useful Post:
Dynorob (7th June 2014)
Reply
Tags
air, dci, flow, location, maf, mass, scenic, sensor
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
