Re: Megane scienic front windsreen wipers wont work
There won't be a relay as such,the wipers will be controlled via the UCH control unit.
The first thing to check is to see if power is getting to the motor and then you can work back from there.It's possible that the linkage has come off of the motor,this is something else that needs to be checked.If there is power getting to the motor and it's not working then the motor it's self is suspect and the earth needs to be checked to confirm this.If there is no power then the switch needs checking and then the UCH.
If the UCH turns out to be suspect then sometimes disconnecting the battery for a while will 're-boot' it and it will reset it's self,other times it will need to be replaced which unfortunately isn't cheap and it will also need reprogramming to the car.
__________________
I'd rather push my Alfa than drive a BMW....
Currently in Lagdti's garage: 2003 Alfa Romeo 156 2.4 JTD Sportwagen (estate to you and me!), 2002 Alfa Romeo 147 2.0TS Lusso soon to also be in many pieces,and now a 1994 Land Rover Discovery 300Tdi with a 2'' lift kit and some girt knobbly tyres on it....
