Hi Folks.
Hope I have more luck with suggestions on this query than on previous ones for my Clio, none of which has inspired anyone to put fingers to keyboard! Strange - there's usually so much help here.
Since we bought this Scenic July 2010 it's been a poor starter. It's been looked at several times and the following things have been done:
All pencil coils replaced
TDC sensor replaced
New air filter
New spark plugs
New cambelt, water pump (not related to starting problem, just needed doing)
It takes numerous turns of the starter to fire and then is 'lumpy' until the accelerator is blipped. This is usually accompanied by a strong smell of petrol. Once this is out of the way, however, it runs pretty smoothly and sounds fine.
Compression has been tested - within tolerance on three cylinders, about 15% down on the remaining one.
No coolant in oil or blowing into coolant.
It's just a feeling, but I have got the impression that it starts better on a cold, frosty morning than a warm one.
If I re-start within a minute or two of stopping it usually fires within a couple of revs, whether the engine is warmed up or not.
Could the air inlet temperature sensor be faulty?
Could an injector be faulty?
Can't afford endless trips to the garage for hit-or-miss diagnostic work and anyway the car's been on analysers several times in the last few months and no obvious faults have been found - no fault codes.
Any ideas anyone - all suggestions (clean ones) gratefully received!
Thanks.
Oh - and if you could take a look at my Clio queries I'd appreciate it - just search for threads under my handle. Cheers.
TDC sensor replaced
New air filter
New spark plugs
Thanks.
