Hi guys a friend of mine wired up some after-market RPM, TEMP, VOLT gauges up to his clio.
Now after it was wired up the car started going into limp mode.
took it too a garage and apparently were he spliced into the cable on the coolant sensor apparently have sent a signal to the ECU and have blown something.
According to this electrician the ecu keeps thinking the car is over heating so making the car over heat.
How is it possible the the ECU has been blown via after-market gauges.
could there be another problem i am missing?
coolant temp sensor was replaced and problem still there.
also if the ECU is blown what do i need to buy to fix this i know i need an ecu but will i need keys and transponders etc... if i get a second hand ecu as been quoted well over £500 for a new one plus programing
