Hi I have fitted a new engine to a 1.2 8v Clio ( old 1 snapped timing belt) have fitted inlet manifold and other parts off old engine to new 1 and the fitted it to car and when you start it it just revs up straight to the limiter and stays there! Pretty sure every thing is connect bk up. Anyy 1 had any problem like this b4??
Re: 1.2 8v Clio 2003 going to full revs wen started! Help!
Dunno.
Any air leaks.
Check pipe to servo and carbon cannister.
Did you misplace any manifold seals or double up on any.
Did you swap over all sensors, including knock sensor, coolant temp, throttle body ect.
Banned
I would be inclined to disconnect the idle stepper motor plug before starting & see how it goes. Failing that disconnect throttle valve potentiometer & try if not satisfactory post back. Hth Regards Mickeybo
