just bought a 16valve 02
no reason will not start at times
needs 8 or more attempts
immob light always goes out
any help would be appreciated
regards
S
Could be worth looking at the TDC sensor - this is a commonly reported fault on the site. Welcome to the forums by the way!
thanks selwonk
new to the clio
to me tdc means (top d--d c----) yeh
where do you find it?
i know its a pain answerering these dumb ?,s
S
To be honest mate, I'm just the site techie. If you use this form and enter TDC you should find plenty of info including details on where it can be found:
http://www.renaultforums.co.uk/search.php?
Failing that - there are some RTE members including one who is online now. They will be able to tell you exactly where it is. One thing I know for sure - it's worth starting with the TDC sensor cos it's one of the cheapest possibilities! :)
