PPear,
The problem is that the camshaft slots will not stay lined up without being physically locked together.
On the 1.4/1.6 engine, the crank locking pin is threaded into the engine block, and is used to both position and restrain the crank when tightening the pulley retaining bolt.
The locking tools are simple affairs, and could readily be fabricated by someone with the necessary materials and skill. I have neither!
It must also be remembered that the the crank pulley has to come off, and once released, the timing sprocket is free to rotate around the (non-keyed) crankshaft.
Sadly, many people have to come to grief by not grasping this principle
