hey folks, i was wondering if i cud ask for a fair bit ov advice as im stuck in a rutt over my clio it started running lumpy a couple weeks ago looked under hood to find low coolant [just under min] as i undid the res in was realy pressured up? topd up n seemd to run ok for a few days until it startd dropin revs again this time the the water look empty with engine runnin i undid res cap n as it released the pressure the engine ran smooth again n the return pipe fill the res bak up? since then its been getin worse to the point now i think its gona blow up its so clonky on tickover had to top up more an more but theres no sign ov a water leak? also took thermostat out did look stuck shut but only helpd for a short time, no cream in oil but that about as much as i know about checkin for the dreaded headgasket!!! i would realy be thankfull for advice n willin to trade for buildin an renovation advice lol cheers
