wel, i have a 03 1.5 dci clio and it keeps cutin out wen i get to 1800-2000rpm. It stats and ticks over perfect but once i rev it or drive it above 1800-2000rpm it cuts out. I changed the diesel filter, any ideas?
Is the engine management light illuminated at all?.
HI,
Did you manage to solve this? I have exactly the same issue with my Kangoo 1.5 ;-( I broke down at the bottom of a hill so can't get the revs to even move the car. Mine seems to cut out at about 1300 rpm.
Simon
This turned out to be the crank sensor. I had fitted this sensor on a different renault ( a clio) and these symptoms just didn't seem the same.
It was the sensor though. Now sold the van, but hope this helps.
Simon
