I have a set of 15" alloys from a 2003 Clio that I got for my 2005 Kangoo van. I have just tried to fit them and the rear wheels rub on the inside, could use a spacer but would need to be a big one.
Has anyone else had this problem or have I bought the wrong wheels?
Any suggestions welcome.
Discussion Starter · #3 ·
They are fine on the front, clear everything fine.
Just on the rear, they dont touch the arch, it is the other way, they are rubbing at the back of the wheel, prob by around 15mm.
Thought Clio wheels should of been a direct fit???
G
The wheel off set is obviously different looks like you are going to need spacers and longer wheel bolts on the rear if you want to use the alloy wheels. Are they the same width as steel wheels?
