1 - 20 of 57 Posts
Hello all,
Hope everyone is well. Drove my van yesterday, no problem. Parked up normally but today no spark from electronic unit. Replaced HT to distributor and checked connections as best I can; but nothing. I am not very competent or knowledgeable regarding electrical issues and frankly somewhat intimidated by the wiring. Any suggestions would be greatly appreciated and or perhaps contact details of a competent auto electrician. Thanks.
Check to see if you have power to Renix electronic unit , ( should have sticker with RE250 on) there are 2 wiring plugs below HT lead to ign coil , pull out bottom plug , with ignition turned on only ( not starter turn over ) check to see if you have 12v power across the 2 wires , if not , follow these wires to conn block ( about 6inch along ) pull this conn apart and check again - usually bad connection /ground etc , 32 years of corrosion of electrics is the main problem with these old vans - let us know how you get on !
Many thanks OPBob. I have checked connections but will certainly check again in the morning. The van doesn’t have a Coil.
the coil is the square chunk of metal that is bolted onto the renix unit that the HT lead from dizzy cap is connected to :cool:
Thanks again. I will look in the morning. Please excuse my ignorance but I have no idea what a dizzy cap is; the female end of the HT Lead attaches to a metal protrusion on the electronic unit and then on to the distributor cap.
Thank you fellers; OPBod, I have looked for a connection by the HT lead with two wires in order to check for power in to the Unit but failed to find it. Is it possible to identify it in this photo? Many thanks.
182917
Discussion Starter #10
Thanks OPBob, that was quick. My unit is a little different; is it significant that it is RE250? The only plug with two wires appears to be the one that to to the TDC sensor.
Ok - test the plug as shown in photo , if 3 wires , center wire (in plug ) is ground/earth , of the other 2 - 1 = power 12V think the other goes to rev counter if fitted - you can also check the 2 wire sensor plug resistance , multimeter across to 2 wires should measure around 200 ohms +/- 50 ohms , any more or short circuit = knackered sensor.
Discussion Starter #13
Thanks FraserL, OPB & DD(the insertion of the arrow is impressive). I have 12 volts at that point. I have endeavoured to clean connections and earths.
Discussion Starter #14
No Rev counter. Am I asking too much for a complete idiots guide to how to check resistance? I have a multimeter but only ever used to check volts.
Discussion Starter #16
Turn your meter dial to this symbol
I achieve a reading of 184.4 so I’m guessing o need to look elsewhere. Any ideas welcome. Thanks.
Discussion Starter #17
An afterthought: I assume I am checking absence of spark correctly by holding Distributor end of HT close to mental to check for spark jumping the gap?
Is this with the spark plug in the plug lead
Its take a spark plug out, refit to the lead, lay the lead on anything metal on the engine.
Crank the engine you should see a spark,
Discussion Starter #20
I regret that I have no spark either at the distributor end of the HT lead or at spark plug. Any ideas would be greatly appreciated. Thanks for everyone’s input. Keep healthy out there.
1 - 20 of 57 Posts
