1 - 13 of 13 Posts
Hey, i'm new here.... At some point today my front fog lights died... i don't know what or how they have died... all i know is one bulb is out, anbd i get a tick from the relay...
could this be partially knackard? or are they like crimbo lights... when one goes they all go????? can somone help please..
Hi cyka
The tick sound from the relay could be good news (they do give a click when they operate).
If one bulb is working then the fuse is good,try either a new bulb in the other or swap the bulbs round.
Even better if you have a meter check for 12 volts in the bulb holder.
hope this helps.
Discussion Starter #4 (Edited)
The Light on the dash shows... i forgot to add that... but neither light works... and where is the fuse for the front foggies... i found the one for the back... as that one went walkies... dunno where but it went walkies and my back foggies didn't work :( fixed that one but i don't know where the front fog light fuse is.
Discussion Starter #12
i had the lights out earlier on today... nothing appeared out fo teh ordinary apart from teh blown bulb.... teh filament was moving like it had brokem... so blown bulb there....
Discussion Starter #13
well still no luck with my foggies... anyone got anything to build on what chrism has suggested?
1 - 13 of 13 Posts
