Hope that someone can advise/help as a search hasn't come up with answer.-
Problem: Vehicle will start perfectly for weeks /months then will not operate starter motor when key turned. No audible clicks, no dimming of dashboard lights everything normal other than inoperative starter. This happens intermittently and occurs whether vehicle is hot or cold. The problem rectifies itself if left for a few hours or if vehicle bump started.
I suspect a relay problem however, despite best efforts I can't for the life of me find where they are. I've consulted Haynes-not very helpful other than indicating that there are 2 relays. Does anyone know where they are located and shed any light on the problem?
Many thanks
ian
Hi it may be the starter motor itself or even the solenoid on the motor thats the problem????
