Hi all. I've got a 1994 espace and am having problems with the roof linings. Because its a air con model it has no sunroof's and the two rear roof linings have both come unstuck. I have tried carpet tape, strong double sided tape and various spray glues and masticks but nothing lasts more than a day before it drops off again. Has anyone else had this problem and managed to overcome it?
Hi sorry not had this problem, but this might help you i have a glue gun that takes those 4'' glue sticks which you can buy from £6.99 and up normaly with about 10 glue sticks with the gun "Woolworths" i use it for everything but if you do this i would stick bit at a time as the glue sets within secs,i hope this help you all the very best Donald
I had though of using a hot glue gun but the backing to the roof linig is a very soft foam and i think the glue will just melt into the foam and possibly damage the lining itself. Thanks for the idea though, something has got to work!
