Hi all,
my scenic has got cold start issues, did have more going on but an Idle Control Valve seems to have cured it.
On cold start, it will catch and rough idle but wont rev for a few mins without stalling. After it has caught proper it will run but splutter when the clutch is released. When this clears the car will run all day and can be restarted without issue. It only happens after a full night cooling down.
Is it the cold start sensor? If so where and what colour is it?
Or could it be the MAP sensor, again which one and where?
And any ideas of an online shop that will stock reasonably priced sensors?
The motor also has an issue with the instruments (just temp and fuel) they behave like they have a bad earth so are reluctant to deflect, then (after a couple of miles) read correctly (simultaneously). Ive had the dash to pieces and found little wrong but cant locate the earth.
can anyone help a Renault virgin please?
Chris.
Chris.
