can anyone give help in removing the dashboard on these cars, i can only work out how to get the top panel off(the one on top of the digital speedo) i want to remove the areas at the front where the heater controls are on both sides and the area by the steering wheel(the fabric covered sections)
please help Mark
Did you ever manage to get the dashboard off. I find I need to get to the area above the clutch pedal to replace the clutch cylinder. It looks a mamoth job to get the dash out.
Hi i have took most of my dash on my 2002 espace apart you will need to remove the top past first,you will need a set of torque keys or torque sockets and then starting from below its a slow process and a bit a time basically as you remove one part and the next becomes visible i hope this helps Donald.
I think you start by removing the speaker covers on top of the dash, left and right they pop of and pop back on, under neath are the torx screws to remove the whole top panel above the speedo.
