Hi just had a neighbour ask me for advice, its a base spec megane r reg, 1.4 presume its an 8v.
Says he has problems starting only from cold.
Im thinking the coolant temperature sensor, also check the plugs and crank sensor?
Is there any common problems?
Andy
hi m8:) as you have said the Top Dead Centre is very common but this will also give problems on start up when its warm aswell but worth a shot, as to the temp switch do you no if it miss fires? also do you no if its losing any coolant?
but tbh an engine service would be my advice m8 plugs,air filter, oil ect especialy if its been somtime since its last
good luck alex:)
