Hi, my first post and a problem.
I have just bought the above car,which has only been a taxi for 40k,
with a staggering 148k on the clock. The engine sounds good now I have replaced the pencil coils, although I have to weld or replace the manifold or gasket as it has a slight blow. But what is driving me mad, is when I turn left I get a squealing noise, almost a grating squeal. Also when I reverse on a lock I have got a slight groaning grating noise, which you can also hear if I bounce the wing up and down I suspect it could be a shock absorber or spring. However a friend says a dry c.v joint and to get it greased. Any help appreciated thanks, oh and I'm in Plymouth.
