1 - 8 of 8 Posts
Hello, this is my first ever post, but I'm glad I've found this forum.
There were some wet patches on my driveway, and looking underneath the engine I see that a little clear oil is present around the edge of the hole in the middle of the plastic engine cover.
The engine cover is bowed and the cap doesn't seem to fit - is this normal for an 8 year old vehicle which still runs well? What is the most likely cause of a slow oil leak which is only expelling clear oil, and is it serious?
Many thanks.
Keith
I'd remove the under tray and have a good look,Keith.From your picture it does look like engine oil,but power steering fluid leaks are common.The pipes for the system corrode and leak,but you'll usually notice that the steering gets noisy as the fluid runs out.Also,gearbox oil leaks are quite common,and can lead to premature gearbox failure.
I'd definately have a look for the leak,or at least get it checked out.
Welcome to the forum,by the way.:)
hi there id agree with all the others! by the looks of the under tray it would seem it has been a leakage for sometime! if this substance is of a srt of clear liguid does it smell? id be checking for a diesel leak or it could be from the hydrolics system! have a noise ound with top engine cover off and have a good look around check the brake reservoir!
Discussion Starter · #5 ·
Power Steering, I think.
Thanks all. I took off the top engine cover and had a poke around, and there is a little pool of something near to the inlet for the power steering fluid, the jubilee clip also being a bit damp. I had to top up the PS fluid with about 150ml, which I last checked a couple of months ago, so I guess it is this. The engine oil (from the dipstick) is black, so it's not that. Brake fluid and coolant are also looking fine.
Is it ok to keep topping up the PS fluid for a couple of weeks until I can get to a garage?
Cheers.
Power steering leak
Hi Keith, At least you have found the problem. Keep a very close eye on it and if it were mine I would check it at least every day. If it runs out of fluid you could end up damaging the steering pump or worse still the power steering rack. To repair them could cost £200 - £1000.:)
1 - 8 of 8 Posts
