1 - 8 of 8 Posts
Hi, the garage that mot'd my wifes 1.6 16v advised that the exhaust maifold has split/cracked.
Is a repair possible or do they not take kindly to being welded?
Yup, it is possible to have them welded but for how long it will last is another matter. Its also hard to find a welder that will do it.
I've had mine welded but i don't have much hope for it lasting forever, so i'm also actively looking for a new one just in case - i'd suggest you do the same ;)
Ho hum! Thats what I thought. In which case, are all the 1.6 16v manifolds the same or does it have to be a coupe?
Is the 1.4 16v manifold the same?
Pete
Pete
I'm not a mechanic, but i'm sure someone will come along with an answer shortly. They are quite rare though (because its such a common problem!) so put the feelers out and keep searching ebay :)
I'm not sure if the 1.4's are the same,but I do know that a new one from Renault is around £500......ouch!.Also,most scrappys have cottoned on to the fact that it's a common problem and charge a premium for second hand units.
I think the manifold on my 1.8 16 valve is beginning to go too......:(
There are 2 different types of manifold fitted to the 1.6 16valve (K4M) one type has a built in catalytic converter (cat) and the other has not. If it is of the type with a cat then there are then a further 2 variations which are not inter-changeable (different stud patterns) to get the correct manifold you need the casting number stamped on the righthand side of the manifold. Try CIT-REN LTD 01508 558655 they mail order late renault spares
1 - 8 of 8 Posts
