I am having a problem that is bringing my FUEL INJECTION FAULT warning light on.
Having read previous threads I gather that the EGR valve can cause problems, and can possibly be cured by cleaning if it is sticking.
Which one is the EGR valve? I think it is on the right (from the front of the car) just below the Inlet Manifold, with a multi pin electrical connector on it and about 1 1/2" diameter with 3 bolts securing it. I have tried to remove it by taking out the 3 bolts, and although it is not clamped tight now it will still not come out.
Can anyone confirm if I'm on the right trail, and any tips on removing it would be welcome?
Thanks Taffny.
Thanks Taffny.
