Hi all,
The saga with my Espace continues! (Espace IV)
I have recently rebuilt the engine as the old block was scored. Fitted a new block and set the engine up as per manual. Put the engine back in and plumbed it up.
When it finally started it sounds as though it's running on 3 cylinders and has absolutley no power and struggles to rev. It also smokes like Dot Cotton.
It has had a brand new turbo and a full set of recon injectors. The head was checked and two valves were replaced. As far as I can tell the engine should be great. Problem is it isn't.
I have checked the compression and I'm getting over 300 psi in each cylinder.
I've got nearly all day tomorrow to go over it so if anyone has any suggestions on what to look for I would be grateful.
TIA.
TIA.
