1 - 10 of 10 Posts
Hi everyone,I have a problem with intermittant poor starting and/or stalling ,worse when cold.Car otherwise runs very well.I fitted a new EGR valve recently that smoothed out the general running of the engine but did nothing for the stalling problem.Any advice appreciated.
how many miles has it done?
check glow plugs, if it is only differcult to start when cold:)
also listen for the relay click when the plugs are warm maybe 30 seconds after the actual light goes out.
Cheers Espaced? Would it be glow plugs if the engine's already running but stalls at first corner, and then restarts instantly?
possible:confused: does it run ok after a few minutes of driving?
Hi espaced,today it started and ran perfectly on two trips of 5 miles and then messed about when restarting when still warm!!!
2.2DCI Stalling
Looks like I've now solved this problem with a new engine speed sensor.Just cleaning the old one sorted it but for £23 I thought I'd spoil the old girl.Thanks to anyone who got involved.
can you get a picture?
Discussion Starter #10
Hello espaced,Can't really take a picture of the new one as it's behind the undertray.It's the L shaped sensor retained by a spring clip that looks at the flywheel,just turn and pull to remove it.
1 - 10 of 10 Posts
