hi i have an espace 2.2td 1999, the car takes about a minute to fire up there is smoke from the back of the car like grey to white or light black, took the car on a short run, still smoking and it has no power, very slow can you please help been working on this car for 3weeks HELP HELP, thanks
Your pump timming has to be wrong still does it knock when reving or is it just slow to pick up ?
on tick over it will rev a little sluggish at first. when driving no power, when the engine is ticking over its quiet, on driving its loud cheers alan
should have just sent it to me lol
Sounds like you need to get another look at the belt i know its a pain but the pump is so easy to get wrong i done it a few weeks ago on 1 thought i could just clip it with crock clips but it still managed to move !!
Spent longer trying to sort it than i did doing the belt again once done ran fine first turn.
thanks will look again tomoz the pump timing looks as if it is at 3 o`clock cheers alan correct me if im wrong
