any one know if it is possible for a DIYer to replace this belt on my clio. 1.2, 2000 reg, with P steering.
If so, simple instructions would be great
thanks
Barry
Hi barry.
It's a piece of **** to replace belt. If it were me I would replace both belts.
To remove p/s belt you will need a 40 or 45 torx and 21mm spanner. Hold outer part with spanner and loosen torx. This will slackened tensioner on belt. Remove and refit belt. Tension by turning spanner till belt is tight. Tighten torx.
Be CAREFULL not to remove torx compleately
On alt.
Slackened studs on alt mounting points. Alt should slide down allowing belt to be put on. If treaded bar showing with nut for 10mm spanner, tighten nut tp tension belt. When tensioned tighten all studs
