Hi the indicators are working fine but in neutral position [off] the relay is clicking away, suspect stalk control.
To remove, the steering wheel and a/bag must also be removed to access the screws?Any procedure advise for this?
It will be he contacts in the indicator stalk. You dont need to remove the steering wheel just the cowl around the collum and then i think its 2 small screws holding the stalk on. Dissconnect the plug and remove it. You can either take the stalk to bits and clean it or go to a breakers and for about a tenner get another stalk. Just be aware of what funtions you have on the end of the stalk and get one to match ie have you got fog lights and lights or just light switch. The stalk was common to loads of renaults like the megane and the senic.
Hope this helps.
