Hi there,
When I first start my car there is a ticking noise coming from the engine, after around 15 minutes it stops. does anyone have any idea what could be causing this. A friend thought it could be time to replace the timing belt however the renault garage say the belt should be changed around 60,000 miles (I have done 40,000).
It has recently been serviced and is certainly running much smoother but as I say I have no idea what is ticking.
Cheers
Timing belt life time warning
Outside the UK, Renault quote 4 years or 72k but many car makes need belts changing at 50k but this is only a guide. However, belts can fail before this time.
