If df254 is saved memory lost, its a fault that 90% of Meganes and Scenics have stored in its memory, normally just refers to a flat battery at some point. Nearly always ignored by the dealership, unless your car is a non starter. When you say oil solenoid, are you refering to the dephaser oil flow control solenoid, the oil pressure switch, or the oil pressure control solenoid in the auto gearbox? also can you send us vehicle type ( the 4 letters after vf1 in your vin, and registered build date of your car )
