Despite numerous repeat visits to two French Renault main dealers over the last year, my RX4 still periodically (ie at least once a fortnight) refuses to start. The Ignition switches on and the engine turns over OK, but it won’t fire up. It has also occasionally suddenly stopped, eg after hitting a speed hump a bit too fast! The ‘no start’ fault can occur both with the engine cold, or hot after an otherwise smooth run.
This problem was initially – and several times subsequently – put down to a duff TDC indicator module. This was changed (for €160!) but the fault kept recurring. Then the TDC indicator wiring to the EMS(?), or a connection along it, was blamed, so the wiring and connectors have been changed – twice - (another €70; 2nd time uner warranty), but still..... And of course, when at the garage, the Diagnostics tests never show up any problem!
I then learned from a very helpful EuropAssistance man (called out to yet another ‘no start’) that if one reaches down into the engine bay and gently ‘jiggles’ the wires near the TDC module, the engine fires up as soon as the ignition key is turned again. So as the Renault dealer ‘experts’ have failed me, this is now my standard practice on such occasions!
Problem is, my wife can’t/won’t drive the car alone, as she wouldn’t be able to reach far enough down into the (most likely, hot!) engine bay to reach the TDC wiring.
But could the fault be somewhere else on the car’s electronics systems (lambda sensor, immobiliser....), and the ‘wire jiggle cure’ is only coincidental?
Advice welcome please. The car is the 2.0 petrol-engine RX4 model, manual gearbox, and it’s only just clocked up 100,000 miles.
