hi ive got the clio service/airbag light coming up on my dads clio, i had the same problem with my 2002 clio and just cut and reconected the blue and orange/purple and then the brown and brown together from the grey/yellow box thing. i done the same with my dads with no luck, i have just done a search to see if there were any other cures and couldent find any. ive now cut and reconnected the all the wires from the grey/yellow box testing them one at a time and no cure then i looked under the passegers side and saw two wires that looked like they had been soldered and then had a black sleeve heat shrinked over so it took the heat shrink off and the two wires were soldered so i cut and reconected them and still i have no luck.
any suggestions appresiated
dan
Did you move any of the front seats before the airbag light came on? If the answer is yes then whichever one you moved is the side you need to look at. If not then it could be a steering wheel bag fault. Time for a plug in maybe?:(
