1 - 18 of 18 Posts
Hi!
The other day it seems a local smack-head helped himself to my drivers door wing mirror cover (no evidence of collision/broken tabs etc....).
Managed to find one eBay for @ £15 but am having the devils own job trying to match the colour in spray cans from Halfords.....
Any ideas? It's a 2002 model, "silver" in colour, although I think there's a hint of blue in it.
The spray can charts (and youths employed) at Halfords don't offer any help at all! :steam:
Thanks for looking.
Steve
Hi there Steve - check the chassis sticker on the driver's 'b' pillar (the same one your seat belt would be fitted to).
You are looking for a code which is in the format MV632 (which is Gris Boreal) or D47 (which is Storm Blue).
I'm sure there is a database on the forums which explains this further.
If Halfords can't help - and heaven knows it doesn't take mauch to confuse them - there will be an automotive paint supplier in your area who will make up aerosols to order.
I would advise that you paint the cover before fitting it - make it easy for yourself.
Check out my guide in the 'how-to' section of the forum if you want a bit more info.
All the best,
Paul
Cheers, Paul.....appreciate the reply.
Painting it's not a problem, I've got a bit of experience on that side, but it's just matching the colour! :confused:
I'll have another gander at the plate over lunch tomorrow and then see if I can confuse the Halfords kids some more! :devil: :)
Steve
im also looking for the right colour for my 2000 clio. I find halfords to be nery unhelpful
Would my local renault dealer stock the paint?
If you are looking to spray paint go to a local car paint supplier - renault usually do small touch ups only:)
Be advised many paint finishes are a two coat process with a base colour covered in a clear laquer
I have those two pages of Renault colour codes, but although description matches to what VelSatisfied said earlier, I think it relates only to Sikkens pints.
I might be wrong though.
Worth trying T-cut but in all honesty wihout being able to see waht depth the scratches are it is hard to know - go on give it a go:)
hey guys
I have looked at the infomation on the driver post. And found that my paint number is mv635. But when i have looked at the infomaion chart i cant find my number.
Anybody have any ideas?
thanks
fred
Hi Fred, I've just checked my paintcode book, and MV635 is Metallise Vernis Gris (a metallic grey/silver).
Any automotive paint supply shop (which make up their own paints) will be able to supply a quantity (either in a touch-up or aerosol form), based on that code.
Hope you get it sorted out (its been a long road).
Paul:)
hey guys........
was spraypainter when I was young*er*...
..so we allways kept leftovers ........ we gave little amounts to (future)customers for a coffe and a icecream......
I'm sure there is a panelbeater close to you
1 - 18 of 18 Posts
