Hi i have a 02 megane scenic 1.6 16v i attempted this morning to change the rear pads (disc model) and could not get the `plungers to return to allow for the thickness of the new pads can anyone suggest how to get the `plungers to return
cheers steve
Because the handbrake is operated by the pistons,they need to be pushed in and turned at the same time.There is a special tool for doing this,but usually a strong pair of long nosed pliers will suffice.Push the piston in and turn clock wise together and you should find they will go back in.If not,then there is a problem with the caliper somewhere.
