Hi everyone
Not been around for a while as I have been sorting out a new career!
A quick question about the hazard lights on the 2003 Clio.
When I press the hazard button nothing happens. Is there a way to check the wiring, or does anyone know of this problem and have a solution?
I admit my knowledge on cars is pretty poor but my car failed its MOT this week on this.
Thanks in advance.
Hi there, do the hazard lights flash when you set/deactivate the alarm? If they do, then its more likely that your problem is with the hazard switch itself rather than the wiring.
If your knowledge of cars is limited, it may save a lot of grief by taking the car to an auto electrician who can repair the problem without possibly creating more issues.
Sorry if my answer sounds a bit blunt, but I've seen all too often the mess/expense that people get into because they ended up over their heads.
Paul:)
I have experienced the same problem. However if I tap the switch instead of pushing it then the switch popps out and hey presto the hazards work.
