hi need help my drivers side window can open and close when the key is out of ingnition and when i leave the fuse in it drains my battery overnight but when i take fuse out its ok wher is the problem i disconeted the cables form the switches and connected them beck still same plus i need to press the switch like 10 times for the window to open fully and close ??
Scenic mk1ph2, RX4, ID35s11
hi
the parts involved are.
window switch, window motor unit, UCH.
try a different switch and motor, it should be possible to remove/refit the motor without needing to replace the entire mechanism.
if still no luck then its the uch, which probably needs removing and cleaning, you may have a water leak form the sunroof to check for as well.
oh and for refitting the seal on the doors, try using laguna 1 door seal roll (mastick on a roll @ £8 instaead of £65 for a roll of lag2 door seal strip)
just remember to stretch it out a bit as you put it on.
