The fan on my 2003 Scenic is not working on any setting. Looking through some of the other postings, I understand that if the fan is not working in positions 1,2, and 3 but works in position 4 then the thermal fuse has gone.
Just to be sure, I located the resistor pack under the top facia panel, removed it and checked the fuse with an ohmeter and it is intact.
Whilst I had the resistor pack out, I was able to see the fan impellor, and was able to turn it with my fingers, so it does rotate.
To narrow this down, since there seems to be so many variations, my resistor pack has 3 connections to it, a large rectangular multipinned connector, a 3 wired small connector, then red and black heavy wires, terminated in a connector which goes down to the fan itself.
If I put 12 volts directly across the red an black wires, assuming the fan is OK, should it spin, or are there other components hidden somewhere ? I read in one post of a relay which is behind the fan, but I cannot feel one.
Does anyone know how many ohms I should read if I put the ohmeter across the red and black wires coming out of the fan ?
Final question, if the fan is indeed dead, does removal and refitting require the ac system to be degassed and regassed as stated in the Haynes book ? Since my set up appears different to the set up in the Haynes manual, wanted to make sure.
Thanks in advance for any input.
