Hi everybody,
please help.
I have a 2004 megane cc 1.6vvt dynamique with the following problems:
When changing gear, the revs rise and do not fall, as if the accelerator is sticking.
Also, when pulling away, the engine seems to die, then moves again, almost as if the accelerator has not been pushed hard enough.
The car always starts, but sometimes stalls when you start to move off.
My local dealer says he has re-programmed the ECU but it has not helped.
Please help with these problems because when I take people out in the car it looks as if I can't drive.
Thanks, Peter.
Banned
hello there m8, sounds like a very much the same as the problem as my megane, try the map sensor a little box with a small black hose connected to it opull the hose off and see if that helps m8
matt
search for my listing in engines under help or the megane gets it
lol
link to a web site on there
hope this helps keep us in formed
Hi M8:) I'm Not Sure If This Applys To You, But If It Has A Dual-mass Fly Wheel and its playing up This Can Give The Same Symptoms As Your Experiencing Aswell.
