Just bought a 2004 Renault Scenic 1.4
When I double click the Lock button on the key card to lock the car and close all windows one of the rear windows actually opens. Also, the open/close action on the driver door is reversed for this particular window. Something tells me that side of the car had had a crash and was fixed. Probably had some work done on that particular door. Where should I start looking?
Julian
It sounds like the wiring has been switched round! Not sure how this has happen but i think it may be the wiring on the motor control module or something to do with the regulator being reversed!
If its the same as a Laguna 2 someones probably done what i just have.Fitted new cables to the window machanism and wound the cables round the pulley the wrong way thus reversing the motors action:loser:.i think the only sensible solution is to redo the cables.
