Hi, Just bought some front pads for my new shaped Scenic 04 plate with 1.6 engine . I believe all Scenics of that year at least are the same.
So can anyone tell me what the torque setting is required for the 2 bolts on each caliper. I require the reference from a known source ie Haynes Manual ect (i do not mean to offend those that say "fairly tight" will be OK).:)
Have bought Renault pads in the past which had torque settings in the box but not in these.:mad:
Just for info the renault part No is 7701209444.
Cheers, hope you can help ???
Glyn
Torque
Hello, in my Haynes manual it quotes 32Nm / 24 lbf ft for the brake caliper guide bolts. Hope this helps, regards Damian. :)
Thanks Damien, One more question
Damien,
Thx for that info that will let me get on over the weekend.
But !
Opened the box of pads but there are only 2 replacement bolts but 4 are used to hold the calipers any ideas anyone.
Glyn
