Hi, I***8217;m looking for some assistance with a clutch issue. My pedal was going soft and to the floor then occasionally getting some pressure back. I changed the master cylinder behind the pedal back bleed it with a large syringe, go a good pedal first bleed and it was good for about 4/5 days then same thing happened pedal going to floor and not returning. I bled it again and it was the same ok for a couple days then back to being soft and pedal not returning. I***8217;ve got no leaks or fluid loss. It it likely to be the cylinder in the box or even servo ? I***8217;ve though about trying another cylinder behind pedal just incase its faulty.
CS cylinder by the sounds of it
Afraid its box off, and change it..
I'll bet there is a leak somewhere.
Got an undertray?
Remove same & Park on clean dry concrete.
Could too be top Hat seal outside Gearbox.
