Hi, hope someone can help me with my car issue.
My 2005 Megane 1.6 petrol has a strange fault. When first started, the engine runs ok but if you press the throttle the engine seems to want to cut out. If you leave it for around 30 seconds you can rev it as normal.
Once it's warm the tickover seems really low, around 700rpm, and the car shakes as if it wants to cut out. Also when driving along (performance is good) it seems to hunt, but the throttle is really sensitive so could be this.
The coils have apparently been replaced recently (by the old owner) but this issue continues.
I've read that it could be the coolant temp sensor, but have since changed this, but no improvement. I've also cleaned the tdc sensor, but again no improvement.
Any ideas regarding this fault would be really appreciated.
Thanks.
Thanks.
