All my rear brake lights are no longer working. I have checked all bulbs and fuses and no reason found for this. I have also checked the brake switch and this is also working fine. I have checked the voltage coming through the output pin on the brake switch connector and this is fine. I have even ran a cable joined to this output to one of the bulb assemblies and this is working. Anyone any ideas were to check next or know why this is happening.
Hi. It appears to be a broken wire from the switch to the rear lights. Iirc there is a connector under the carpet on the passenger side for the rear loom. Check the wiring to there from the switch and from there to the rear lights
Sent from my HTC Desire using Tapatalk
