I have been looking through the forums for a solution to the "Low Battery" problem but not really getting anywhere.
My car is a 55 plate Scenic 2 1.9 dti with the handsfree "keyless" card system.
I last drove the car 2 days ago and all seemed well.
(Hopefully this is not a red herring but I did stall the car about 30 secs before I parked up and may have pressed the start button as the car was still moving, probably about 10 mph, surely this would have cause the error though, would it!!!!!!)
When I press the start button the start sequence seems to progress normally i.e. dash display illuminates as normal, steering unlocks, oil level monitors ok, up to turning the engine over where I then get the "low battery", "low oil pressure" and "parking brake fault" etc warnings on the dash display, the radiator fan runs on for approx 5 minutes then stops (seems to run fast for 2-3 mins then slow for the remainder).
All other electrical and electronic functions appear normal.
I tried a jump start but made no difference. I have removed the battery and recharged over night so that should be ok. Whilst I had the battery out I checked for water ingress but there was none obvious and I have re-seatted all the connectors I could access.
I haven't checked all the fuses or relays in the fuse/relay box (RHS next to the battery whilst looking at the windscreen) as I'm not sure how it comes out, not looked at it closely yet but any clues??
It appears this has been mentioned before but there doesn't appear to be a definitive solution. Best I can see is either wiring from the fuse box to the unit behind the battery, not sure what it is called, or Renault charging lots to replace injection computer, ECU, other electronic units etc. Unfortunately I live 30 miles from the nearest Renault garage anyway and a bit stuck without a car.
Anyway, all help would be gratefully received.
