Ive just bought a 2008 clio with a double sunroof, great to have if it works but its completely dead
I havnt got a clue about cars but can anybody give me an idea of where to check or what fuse it
should be, ive had a quick look but cant see any any blown.
can anybody help ?
Probably just needs resetting.
Got a button & a knob in the headlining?
Best done with engine running, to keep the Volts up.
Loooong press on the Button, Should do a shuffle.
Then work.
Once moving, get some spray grease into the runners.
I have a similar problem, sunroof totally dead, tried the long press reset but still nothing.
Can anybody tell me where the sunroof fuse is located and any other checks I can do.
If it still not working , is it just the button and dial switch that needs replacing ? Where is the motor located ? Can I bypass the switch on the motor to see if it's the motor that's dead and not the switch ?
Any help appreciated.
