1 - 1 of 1 Posts
I have a Megane convertible reg. 2009 MK11
The N/S front window has stopped working and I have changed the regulator and have tried plugging in a replacement motor which has not worked.
does anyone know if this could now be the plug/coupling between the door and the main car body?
If so which connector is it? Do I have to remove the door to get access to this?
What voltage should be coming through the pin?
Or can anyone suggest anything else this could be?
It started to operate on and off and then suddenly stopped!
Can I also operate the roof without putting this window down as I do not want to damage anything!
1 - 1 of 1 Posts
