Hi does anyone know to anywhere breaking a 1.9 dci scenic 3 anywhere. I need some bits. Found loads of 1.5 but no 1.9. Got a horrible knocking noise that comes and goes Air con compressor is playing up thanks
if you're just looking for a s/h air con compressor - get its part number - you will find it's common to the 1.9 dci fitted in others - i've fitted compressors to a 1.6 mk.2 and a 1.9 dci mk.2 g-scenic and matched numbers, pretty sure there are only 2 types constant output and variable output types of compressor.
